NXP® i.MX 8M Plus
Computer on Module
Verdin iMX8M Plus
- Modern System on Module form factor
- Up to four Cortex-A53 1.8 GHz processors
- Cortex-M7 processor with speeds up to 800 MHz
- Neural Processing Unit (NPU)
- Image Signal Processor (ISP)
- NXP i.MX 8M Plus applications processor
- Linux OS Support included
Highlights
The integrated neural network processing unit (NPU) was designed from the ground up to execute deep learning inference, and to outperform CPU- and GPU-based solutions in the same power range by several times. Toradex provides integration with popular machine learning frameworks, such as TensorFlow.
Toradex closely partners with leading providers of embedded camera modules to offer you a selection of easy-to-integrate camera solutions, reducing time-to-market and risk.
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M7 processors for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low-power mode or to increase security. The Cortex-M7, with a clock speed of 800 MHz, is a fast and capable microcontroller.
Simplify your design with pre-certified wireless options — from the module to the antennas — to make end-device certification processes more predictable while cutting costs. The latest 802.11ac standard and support for multiantenna setups contribute to a great end-user experience out-of-the-box. These are paired with Bluetooth 5 support to offer high performance and compatibility with the latest Bluetooth devices.
The NXP i.MX 8M Plus SoC comes with up to four powerful, 64-bit Armv8 Cortex-A53 cores, making them a cost-effective choice for running Linux with a modern graphical user interface while providing sufficient power reserves for typical industrial and medical applications.
The Verdin iMX8M Plus is pin-compatible with the other CoMs in the Verdin family. This allows existing Verdin-based products to easily scale and migrate to the new Verdin iMX8M Plus. All of Toradex’s Verdin carrier boards are compatible with the Verdin iMX8M Plus. Extensive product documentation, developer support, service partners and third-party carrier boards are the pillars of our strong Verdin ecosystem.
Operating Systems
Toradex offers free support and maintenance for Embedded Linux and FreeRTOS on the NXP i.MX 8M Plus processor based Verdin iMX8M Plus SoMs. This allows system designers to focus on the application only, instead of focusing also on the OS and low-level device drivers. Other OS' such as Android and QNX are supported by our partners.
Android is supported by our service partner Kynetics. An Evaluation will be provided free-of-charge as a binary installer directly on the Toradex Easy Installer feeds.
QNX is a microkernel-based real-time operating system, primarily targeting embedded systems requiring high safety and security. An evaluation image is provided for Verdin iMX8M Plus directly from BlackBerry/QNX.
Features
High speed dual-band Wi-Fi
802.11ac 2x2 MU-MIMO
Bluetooth 5
Up to quad Arm Cortex -A53 @ 1.8 GHz
Single Arm Cortex M7F @ 800MHz
Vivante GC7000 UltraLite 3D GPU
Neural Processing Unit (NPU) - up to 2.3 TOPS
Up to 8GB LPDDR4 (32 bit)
Power Management IC (PMIC)
Industrial-grade flash memory – Up to 32GB eMMC
Gigabit Ethernet Transceiver
CPU Name | NXP® i.MX 8M Plus |
Microcontroller | 1x Arm Cortex™-M7F |
CPU Clock | 1.6 GHz (A53) 800 MHz (M7F) |
Floating Point Unit | VFPv4 |
NEON | Yes |
L1 Instruction Cache | 32KB (A53) 32KB (M7F) |
L1 Data Cache | 32KB (A53) 32KB (M7F) |
L2 Cache | 512KB |
RAM | Up to 8GB LPDDR4 (32 bit) |
Flash | Up to 32GB eMMC |
USB 3.1 | 1x Host / 1x OTG (Gen 1) |
USB 2.0 | 1x Host / 1x OTG |
Ethernet | Gigabit with TSN (+2nd RGMII) |
Bluetooth | Bluetooth 5.3 |
PCIe | 1 (x1 Gen 3) |
I2C | 5x |
SPI | 3x |
QSPI | 1x |
UART | 4x |
PWM | 4x |
GPIO | 95x |
Analog Input | 4x |
SDIO/SD/MMC | 1x |
CAN | 2x (CAN FD) |
JTAG | 1x |
Neural Processing Unit (NPU) | Yes (2.3 TOPS) |
Image Signal Processor (ISP) | Yes |
Display Controller | Triple |
Graphics Controller | 2D: Vivante GC520L 3D: Vivante GC7000UL |
Video Decoder | Yes |
Video Encoder | Yes |
Display Serial Interface | 1x Quad Lane MIPI DSI (up to 1920x1080) |
LVDS | 1x (up to 1920x1080) |
Digital Audio | 6x SAI: I2S or AC97 |
S/PDIF In / Out | 1x / 1x |
2D Acceleration | Yes |
3D Acceleration | Yes |
HDMI | 1x (2.0a, up to 4K) |
Camera Serial Interface | 2x Quad Lane MIPI CSI-2 |
Size | 69.6 x 35.00 x 6.0 mm |
Temperature | -40° to +85° C(1) |
Power Dissipation | Approx. 1.5W - 6.3W |
Guide MeVolume price starting from $51.90
Get Volume QuoteConfigure Verdin iMX8M Plus
Let’s GoIn Volume starting
from $51.90
Verdin iMX8M Plus
Quad 8GB Wi-Fi / Bluetooth ITPN: 0070
A53
A53
A53
A53
M7
3D GPU
NPU
ISP
VPU
8GB RAM
32GB FLASH
-40° to +85° C
- Sample Quantity
- 1-99
$235.00
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX8M Plus
Quad 4GB Wi-Fi / Bluetooth ITPN: 0058
A53
A53
A53
A53
M7
3D GPU
NPU
ISP
VPU
4GB RAM
32GB FLASH
-40° to +85° C
- Sample Quantity
- 1-99
$177.40
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX8M Plus
Quad 4GB ITPN: 0063
A53
A53
A53
A53
M7
3D GPU
NPU
ISP
VPU
4GB RAM
32GB FLASH
-40° to +85° C
- Sample Quantity
- 1-99
$154.40
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX8M Plus
Quad 2GB Wi-Fi / Bluetooth ITPN: 0064
A53
A53
A53
A53
M7
3D GPU
ISP
VPU
2GB RAM
16GB FLASH
-40° to +85° C
- Sample Quantity
- 1-99
$147.15
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX8M Plus
QuadLite 1GB ITPN: 0065
A53
A53
A53
A53
M7
3D GPU
1GB RAM
8GB FLASH
-40° to +85° C
- Sample Quantity
- 1-99
$107.50
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Configure Your Own Verdin iMX8M Plus
Guide MeGet Started
Verdin iMX8M Plus Evaluation Kit
$736.60
Verdin iMX8M Plus Evaluation Kit 2
$435.60
Carrier Boards
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
- USB 3.0: 1x USB-A (Host)
- LVDS: 1x Dual Channel
- MIPI CSI-2 interface
- M12 lens mount (S-mount)
Videos
Verdin iMX8M Plus - Introduction
Development and Maintenance of your Embedded Linux Vision System – Simplified!
Ecosystem
To get your products to market fast, with low risk and low engineering costs, you need more than just a System on Module with a stable operating system or BSP. We understand this, which is why we at Toradex are collaborating with a wide range of partners to make your life easier. Here are a few highlights. To find more, browse our Developer Page and take a look at our Partner Network.
Machine Learning and Computer Vision
Camera Module
Vision Components provides a large selection on camera modules, which can take advantage of the integrate Image Signal Processor (ISP) of the i.MX 8M Plus. A close collaboration allows a simple integration.
Camera Module
Several e-con Systems cameras are tested and ready-to-use out-of-the-box.
Get Started with e-con SystemseIQ DeepView™
eIQ DeepView™ simplifies the optimization of machine learning algorithms for the edge, taking advantage of the Verdin iMX8M Plus’ NPU.
Get StartedEngineering Services
Antmicro and Toradex have collaborated on several projects in the past. Antmicro has deep knowledge in machine learning and computer vision and can accelerate even complex projects.
Learn MoreModular AI Vision Kit
Modular Vision Kit with Advanced AI hardware acceleration to streamline your development from prototype to production
Rich, Intuitive Graphical User Interfaces
The Verdin iMX8M Plus provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Qt On Demand Webinar: Kickstart your Qt Project on NXP i.MX 8Crank Storyboard
Get started with Crank StoryboardTotalCross
Get started with TotalcrossIndustrial Automation
CODESYS PLC IEC 61131-3
The Verdin iMX8M Plus is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Verdin iMX8M Plus perfectly. You can integrate it yourself, or leverage the expertise of our partner, BE.services, to outsource integration.
Watch our webinar with BE.servicesToradex Easy Installer
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your Verdin iMX8M Plus and choose an OS!
Learn MoreRoadmap
Hardware Roadmap
- Q2'24
- Q3'24
- Q4'24
- Q1'25
- Q2'25
- In Development
- Early access product
- Sample Production
- Volume Product Candidate
- Volume Production
Software Support Status
