Apalis iMX6
The Apalis iMX6 is the second product in the new Apalis module family by Toradex. Complementing the existing Colibri module family, Apalis comes with a wide range of new and exciting features, ensuring customers can develop the most advanced, robust products with minimum overhead and risk. Apalis supports a huge variety of industry standard interfaces, while at the same time providing advanced multimedia and high speed connectivity making it suitable for an almost unlimited number of applications.
Highlights
Equipped with NXP i.MX 6Q and NXP i.MX 6D SoCs, the Arm Cortex-A9 cores are clocked at 1GHz for commercial temperature variants, while the industrial temperature variant has a peak frequency of 800 MHz.
The module exposes a wide range of industrial interfaces including CAN, UART, I2C, USB, PCIe, SATA, and many more.
With a 3D GPU, h.264 encoder and decoder, the Apalis iMX6 is well suitable for multimedia. MIPI CSI-2, parallel, and Gigabit Ethernet cameras are options for video capture, while for displaying an output you can drive multiple independent screens at once through RGB, HDMI, and LVDS.
Based on the valuable input of our customers and our engineers‘ in-depth industry expertise, Apalis brings to market many new technologies. Direct Breakout™ considerably simplifies routing of high speed signals on the baseboard. MXM SnapLock™ provides a unique connector mechanism for module fixation. Apalis also comes with support for ready-made passive cooling solutions for the most demanding applications.
The Apalis iMX6 is pin-compatible with the other CoMs in the Apalis family. This allows you to cost-optimize your design with no hardware redesign costs. All of Toradex's Apalis Carrier Boards are compatible with the Apalis iMX6. Extensive product documentation, developer support, service partners and third-party carrier boards build our strong Apalis ecosystem.
Operating Systems
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the Apalis iMX6 SoMs. This allows system designers to focus the application instead of focusing on the OS and low-level device drivers. Other OS such as QNX and Android are supported by our partners.
Windows Embedded Compact 7 and 2013 is supported on Apalis iMX6. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
Features
CPU Name | NXP i.MX 6Q NXP i.MX 6D |
CPU Type | Up to 4x Arm Cortex-A9 |
CPU Clock | Up to 996 MHz |
Floating Point Unit | VFPv3 |
NEON | Yes |
ARM TrustZone | Yes |
Advanced High Assurance Boot | Yes |
Cryptographic Acceleration and Assurance Module | Yes |
Secure Real-Time Clock | Yes |
Secure JTAG Controller | Yes |
Secure Non-Volatile Storage | Yes |
L1 Instruction Cache | 32KB |
L1 Data Cache | 32KB |
L2 Cache | 1MB |
RAM | Up to 2GB DDR3 (64 Bit) |
Flash | Up to 4GB eMMC |
USB 2.0 | Up to 4x Host / 1x OTG |
Ethernet | 10/100/1000 Mbit with IEEE 1588 |
I2C | 3x |
SPI | 3x |
UART | 5x |
PWM | 4x |
GPIO | Up to 135x |
Analog Input | 4x |
SDIO/SD/MMC | Up to 3x |
CAN | 2x |
JTAG | 1x |
Display Controller | Single |
Digital Audio | 3x SAI |
Parallel RGB LCD | Up to 1920x1200x24bpp 225 Mpixel/s |
Display Serial Interface | 1x dual-lane MIPI/DSI |
HDMI | 1.4a up to 1080p60 |
LVDS | 2x single channel 85 Mpixel/s or 1x dual channel 165 Mpixel/s Up to 1920x1200x24bpp at 60fps |
VGA Analog Video | 1x |
Resistive Touch | 4-wire |
Parallel Camera Interface | Up to 2x 20-bit Frame size up to 8192x4096 pixels 8/16/20 bit parallel video interfaces |
Camera Serial Interface | MIPI/CSI-2 Up to 24 bpp |
S/PDIF | AES/EBU IEC 60958 standard 16x24bit FIFO 24-bit data width |
Size | 82.0 x 45.0 x 6.0 mm |
Temperature | -40° to 85° C |
Power Dissipation | 1.9 - ~7 W |
Product Availability | 2036 |
Apalis iMX6 Quad
2GB IT (WinEC)PN: 0028
A9
A9
A9
A9
2GB RAM
4GB FLASH
GPU
VPU
-40° to 85° C
- Sample Quantity
- 1-99
$224.40
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Apalis iMX6 Quad
2GB ITPN: 0085
A9
A9
A9
A9
2GB RAM
4GB FLASH
GPU
VPU
-40° to 85° C
- Sample Quantity
- 1-99
$217.50
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Apalis iMX6 Quad
1GB (WinEC)PN: 0027
A9
A9
A9
A9
1GB RAM
4GB FLASH
GPU
VPU
0° to 70° C
- Sample Quantity
- 1-99
$174.00
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Apalis iMX6 Quad
1GBPN: 0083
A9
A9
A9
A9
1GB RAM
4GB FLASH
GPU
VPU
0° to 70° C
- Sample Quantity
- 1-99
TBD
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Apalis iMX6 Dual
1GB IT (WinEC)PN: 0035
A9
A9
1GB RAM
4GB FLASH
GPU
VPU
-40° to 85° C
- Sample Quantity
- 1-99
$184.10
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Apalis iMX6 Dual
1GB ITPN: 0084
A9
A9
1GB RAM
4GB FLASH
GPU
VPU
-40° to 85° C
- Sample Quantity
- 1-99
TBD
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Apalis iMX6 Dual
512MB (WinEC)PN: 0029
A9
A9
512MB RAM
4GB FLASH
GPU
VPU
0° to 70° C
- Sample Quantity
- 1-99
$146.20
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Apalis iMX6 Dual
512MBPN: 0082
A9
A9
512MB RAM
4GB FLASH
GPU
VPU
0° to 70° C
- Sample Quantity
- 1-99
$141.10
- Buy Now
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Guide MeGet Started
Apalis iMX6 Evaluation Kit
$763.60
- 4x ARM Cortex-A9 792 MHz processor
- NXP i.MX 6 applications processor
- Parallel RGB up to 1920x1200 24bit, 225 Mpixel/s
Apalis iMX6 Evaluation Kit 2
$408.80
- Parallel RGB up to 1366 x 768 x 18bpp
Carrier Boards
- Compatible with Apalis iMX6Q IT and Apalis iMX6D IT
- 1x Tactile switch to enter Apalis iMX6 module recovery mode
- 1x Tactile switch to reset Apalis iMX6 module
- No special drivers required
- Atmel touch driver
Ecosystem
Toradex Easy Installer
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Apalis iMX6 and choose an OS!
The Apalis iMX6 provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Crank StoryboardDiSTI GL Studio
The Apalis iMX6 is ideal for critical applications where safety and reliability are key. These are also the key focus areas for DiSTI’s GL Studio.
Get started with DiSTI GL StudioTotalCross
Get started with TotalcrossIndustrial Automation
CODESYS PLC IEC 61131-3
The Apalis iMX6 is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Apalis iMX6 perfectly.
Watch our webinar with BE.servicesRoadmap
Hardware Roadmap
For details about the Toradex phase-over policy please refer to the PCN Policy Page.
- Q2'24
- Q3'24
- Q4'24
- Q1'25
- Q2'25
- In Development
- Sample Production
- Volume Production
Software Support Status
