NXP® i.MX 7 Computer on Module
Colibri iMX7
Highlights
Powered by NXP i.MX 7
Equipped with NXP i.MX 7S and NXP i.MX 7D SoCs, the Arm Cortex-A7 cores are clocked at up to 1GHz, making it an ideal choice for powerful yet efficient applications.
Ready for Hard-Real-Time
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M4 for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode.
Power-optimized
The NXP i.MX 7 SoC is a power-efficient processor. In addition, the Heterogeneous Multicore Processing (HMP) provided by the Cortex-M4 allows for a low-power mode where the Cortex-A7 is shutdown to greatly reduce the power consumption.
Torizon for Remote Updates and Fleet Monitoring
Toradex Colibri Computer Module Family
Carrier boards designed for the Colibri iMX7 are not just compatible between the three Colibri iMX7 modules—in fact, they are compatible with the complete Colibri family, including the NXP i.MX 8X, i.MX 6ULL, i.MX 6 and NVIDIA Tegra-based modules. This gives you unmatched flexibility and easy upgradability. Currently, there are eight different modules with over 20 variations available. To make carrier board design as easy as possible, we provide the Toradex Pinout Designer Tool.
Operating Systems
Toradex offers free support and maintenance for Embedded Linux and Windows CE on the Colibri iMX7 SoMs. This allows system designers to focus on the application instead of focusing on the OS and low-level device drivers. Other OS such as Android are supported by our partners.
Torizon Embedded Linux OS
Windows Embedded Compact
Windows Embedded Compact 7 and 2013 is supported on Colibri iMX7. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
FreeRTOS
Toradex enables NXP’s FreeRTOS on Colibri iMX7. FreeRTOS is a real-time OS that runs on the Cortex-M4 core in parallel to the main OS.
Android
Android on Colibri iMX7 is supported by our service partner Kynetics. An evaluation BSP is provided free of charge as a binary installer directly on Toradex Easy Installer feeds.
Features
Up to 1GB DDR3 RAM
Up to dual Arm Cortex-A7 @ 1GHz
Arm Cortex-M4F @ 200MHz
Integrated PMIC
Single 3.3V power supply
Ethernet Transceiver
FRONT
Industrial-grade flash memory
512MB NAND and 4GB eMMC variants
BACK
CPU Name NXP® i.MX 7
CPU Type 2x Arm®Cortex®-A7
Microcontroller 1x Arm®Cortex®-M4F
CPU Clock up to 1 GHz (A7)
200 MHz (M4)
Floating Point Unit VFPv4-D32
Arm® Neon™ Yes
L1 Instruction Cache 32KB (A7)
16KB (M4)
L1 Data Cache 32KB (A7)
16KB (M4)
L2 Cache 512KB (A7)
RAM Up to 1GB DDR3L (32 bit)
Flash Up to 4GB eMMC
USB 2.0 1x Host / 1x OTG
Ethernet 10/100 MBit/s (+2nd RGMII/RMII/MII)
External Memory Bus 1x 16 bit multiplexed
I2C 3x
SPI 4x
QSPI 2x
SIM 4x
UART 7x
PWM 20x
GPIO 126x
Analog Input 4x
SDIO/SD/MMC 2x
CAN 2x
Display Controller Single
Graphics Controller Integrated
RGB 1920 x 1080 x 24bpp
Resistive Touch 4-wire
Parallel LCD 1x
Digital Audio 2x SAI: I2S or AC97
Analog Audio Line in 1x (Stereo)
Analog Audio Mic in 1x
Analog Audio Headphone out 1x (Stereo)
Camera Parallel Interface 1x 8/10/16/24 Bit
Size 67.6 x 36.7 x 6.2 mm
Temperature -20° to 85° C
Power Dissipation 0.6 - ~1.1 W
Product Availability 2035+
Guide Me
Configure Colibri iMX7
Let’s Go
Colibri iMX7 Dual
1GB
PN: 0039
Colibri iMX7 Dual 1GB
  • A7
  • A7
  • M4F
  • 1GB RAM
  • 4GB FLASH
  • -20° to 85° C
Colibri iMX7 Dual
512MB (WinEC)
PN: 0033
Colibri iMX7 Dual 512MB (WinEC)
  • A7
  • A7
  • M4F
  • 512MB RAM
  • 512MB FLASH
  • -20° to 85° C
Colibri iMX7 Dual
512MB
PN: 0081
  • A7
  • A7
  • M4F
  • 512MB RAM
  • 512MB FLASH
  • -20° to 85° C
Colibri iMX7 Solo
256MB (WinEC)
PN: 0032
Colibri iMX7 Solo 256MB (WinEC)
  • A7
  • M4F
  • 256MB RAM
  • 512MB FLASH
  • -20° to 85° C
Configure Your Own Colibri iMX7
Colibri iMX7
1x Arm Cortex™-M4F
Guide Me
Get Started
Colibri iMX7 Evaluation Kit
$515.45
  • Two Cortex-A7 1 GHz processor
  • One Cortex-M4 200 MHz processor
  • NXP i.MX 7 applications processor
  • Parallel RGB LCD up to 1920 x 1080 x 18bpp
Buy Now
Colibri iMX7 Evaluation Kit 2
$336.45
Buy Now
Carrier Boards
Learn more about SBCs and Carrier Boards
Colibri Evaluation Board
Datasheet
Iris Carrier Board
Datasheet
Viola Carrier Board
Viola Datasheet
Colibri Partner Carrier Boards
Supported Modules
USB 2.0
Ethernet
External Bus
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
CAN
JTAG
Entire Colibri Family
4x Host, 1x OTG/Client
10/100 Mbit
Up to 32 Bit
4x
4x
2x RS232, 1x RS422/485
1x
4x
up to 158
4x
1x 4 Bit
1x
Yes
1x Host / 1x OTG
10/100 Mbit
1x
1x
3x RS232
4x
up to 26
4x
1x 4 Bit (microSD)
2x Host, 1x Client (Shared)
10/100 Mbit
1x
1x
3x /
3x TTL
4x
up to 35
4x
1x 4 Bit (microSD)
10/100 Mbit
1x
1x
2x TTL, 1x USB-UART
4x
up to 39
4x
1x 4 Bit (SD/MMC)
Yes
up to 4x Host
up to 2x 10/100 MBit
1x
1x
1x RS-422, 1x RS-485
up to 4x
up to 24x
up to 4x
1x
Up to 2x
Switches
LEDs
6x
4x
up to 3x
LVDS
HDMI
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Analog Audio Mic in
1x Single Channel
1x (Through DVI-I connector)
1x
1x (18 Bit/24 Bit)
Adapter required
4/5-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Dual Channel
1x (18 bit)
Yes
4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (18 bit)
Adapter required
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (Shared with RGB)
1x (18 bit)
Yes
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x
1x
1x
1x
up to 4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
Type Specific Board Connector
USB-to-RS232 Transceiver
RTC on Board
Included Accessory
1x
1x
Mating Power Plug (for X33)
24-way FFC 100mm (for X6)
Yes
1x
Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Yes
1x (*Not Assembled) /
1x
Yes
1x
1x
Yes
1x
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-27V DC
5V 5A
3.3V 5A
200 x 200 mm
6-27V DC
5V 5A
3.3V 5A
100 x 72 mm
-20° to 85° C
5V DC +/- 5%
5V (External)
3.3V 3A
74 x 74 mm
-40° to 85° C
5V DC +/- 5%
3.3V 3A
100 x 80 mm
-25° to 85° C
5-36V DC
-40° to 85° C
Intended Use
Pricing
Minimum Product Commitment
For Evaluation/Development
1 : $229.00
For End Products
1-99 : $79.95
>99 : RFQ
2030
For End Products
1-99 : $33.60
>99 : RFQ
2034+
1 : $69.90
Accessories
Colibri Fasteners
Resistive Touch Display 7" Parallel
  • No special drivers required
Capacitive Touch Display 7" Parallel
  • Atmel touch driver
LM816 USB WiFi
Analogue Camera Adapter
Carrier Board Accessory Kit
Ecosystem
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX7 and choose an OS!
Learn More
Easy-to-use Rich Graphical User Interfaces
Colibri iMX7 does not have a GPU. Nevertheless, choosing a GUI framework that supports optimized graphics on the CPU is a great choice for a modern UI with moderate level of animations. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Qt
Crank Storyboard
Get started with Crank Storyboard
TotalCross
Get started with Totalcross
Industrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX7 is a good fit for industrial automation tasks. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
Get started with CODESYS on Torizon
Matrikon OPC UA
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX7 perfectly.
Watch our webinar with BE.services
Roadmap
Min. Product Commitment
As per NXP Roadmap
2035
Hardware Roadmap
For details about the Toradex phase-over policy please refer to the PCN Policy Page.
  • Q1'24
  • Q2'24
  • Q3'24
  • Q4'24
  • Q1'25
0039 Colibri iMX7D 1GB
0033 Colibri iMX7D 512MB (WinEC)
0081 Colibri iMX7D 512MB
0032 Colibri iMX7S 256MB (WinEC)
  • In Development
  • Sample Production
  • Volume Production
Software Support Status
For latest news release refer
Linux BSP | Torizon OS BSP
Windows
Latest Version
BSP
1.2b4
WEC 7 Microsoft Patch Level
September 2018
WEC 2013 Microsoft Patch Level
October 2018
Stable Version
BSP
1.1
December 2017
April 2018
Implemented Features and Software Roadmap
This list provides an overview about the most important implemented and planned software features for this product on Windows CE. The detailed feature list and roadmaps can be found on the BSP Release Details.
Ready to use
  • Parallel RGB display
  • USB Host (not available on Colibri iMX7S)
  • SDIO / SD card
  • Analog Audio Out
  • Analog input
  • RS485
  • CAN
  • SPI
  • Watchdog
  • RTC
  • Ethernet
  • USB Client
  • Analog Audio In
  • Resistive Touch 4-wire
  • UART
  • PWM
  • I2C
  • Multimedia playback (software)
Have a Question?
